What happened to the teeth?
I had been working on this character for a while and after I was done - when I rendered a scene - I saw that there was this weird thing in her mouth.
The upper teeth deformed. I do not know how. Does anyone know how to fix?
I'm going to leave the image in a link on the mega because I can't load it in the post:
https://mega.nz/file/OhEnXabD#Vh9Z4po-IUqmvatF_8JT4ZmZcPyeP484MOZZaDyMOZU
    It's likely being done by a morph. With the figure selected, on the Parameters Tab find the active morphs and dial them out until you find the one that needs correcting. [could be for shape or a morph pose].
    If product was sold at Daz3D, a ticket into CS should start the process of getting it fixed. {try downloading/installing a fresh copy though in case it was already fixed}.
    In the meantime this is one way to fix some morphs.
    https://youtu.be/XuQwnTd4Fok
  • Catherine3678ab, I found the morph that gave the error. It was a morph to lengthen the legs. When changing the height of the character, that part of the teeth stays fixed... the funny thing is that it was only in this specific morph. When I used another morph to lengthen the legs this error didn't happen. Thank you for your help! :D
  • DartanbeckDartanbeck Posts: 22,159
    Whew! That was Nasty! Glad you got it figured out! yes
    Glad you found the problem, and a solution :-)
    Sadly, depending upon how the morphs are made, it can be quite easy to snag a little more than intended when making the geometry selection.
