Looking for a kite
lou_harper
Looking for a kite. The flying kind. I saw one on Rendo. I wonder if DAZ store has one somewhere buried in a set.
lou_harper
It isn't perfect but depending on how you want to frame the shot, the hang glider part of this ultralight can double as a kite.
https://www.daz3d.com/ultralight
Is it something like this you are after?
Check out the sketchup warehouse, there are several ones there, but you will need to convert them to obj.
you could probably make one from 2 cylinders and a subdivided plane + Dforce weight modifier
Which flying kind? As well as the above a kite is also a bird (related to hawks and eagles).
File upload. Just failed seven or eight times to upload a boxkite obj file. Came up with 'Failed to write file to disc' error each time.
Sorry.
Regards,
Richard
Yes, that is the same problem as with image upload.
Try in 14-16 hours, then it should work.
Yes, like that.
It's no biggie, I can work around it.
https://www.renderosity.com/marketplace/products/127722/prae-kites-for-g3-g8-daz
