Geoshell of a Geograft Problem
JamesJames Posts: 1,191
edited June 2023 in Daz Studio Discussion
There's a small area of a geograft, I want to make a geoshell out of it. But when I made one out of it, the outer edges of the geoshell becomes roundish.
Not a perfect shape of the geograft.
as if the edges were smoothed.
But geograft doesn't' have the option for smoothing.
So what's the solution?
Post edited by James on
  • felisfelis Posts: 6,642
    edited June 2023
    If I understand your problem right, it is not caused by smoothing, but by geometry.
    The shell will keep a distance to the underlaying mesh, but if you have a corner the mesh is pushed in 2 directions. It will be translated along the vertex normal.
    E.g. if you have a cube with a geoshell, the geoshell vertex on the edge will only be 70% (Sqrt(2)/2) above the surface in each direction compared to other vertices.
    Post edited by felis on
  • JamesJames Posts: 1,191
    So what that means?
    It's natural?
    And a geoshel can't be made from a geograft without compromise?
    I will say it is the nature of a geoshell.
    A geoshell is a copy of the underlaying mesh with a given offset. But the offset is based on the normals and if you have sharp corners it will affact the normals, and therefore the direction of the offset.
    Try if you can post an image of your problem, as there might be other solutions.
  • Richard HaseltineRichard Haseltine Posts: 112,003
    edited June 2023
    The Geometry Shell is identical to the underlying mesh, but it gets a Push Modifier with a default positive value to keep the two from being coincident (which renders don't generally like, certainly not Iray). The Push Modifier can be weight-mapped (via Create>Push Modifier Weight node) to exclude or reduce the effect on certain areas, which may help.
  • crosswindcrosswind Posts: 10,357
    I'm a bit lost... A geoshell has no geometry, let alone 'vertex' or 'mesh'. I never succeed in editing a shell with Geometry Editor. Also I don't think a 'weight' could be generated on a Geoshell with any weigh node...
    If I'm right, the OP should manipulate the geograft's geometry with morphing techniques other than the geoshell...
    True, sorry - I thought I had done that in the past.
    You're my true role model ! yes yes
