Apply shader with original UV
I'm sure I have done this before but can't remember how.
I want to apply a shader to an item of clothing but retain the UV so that things like Normal Maps, etc., still work.Holding CTRL while clicking the shader does bring up a dialogue box but when I select "Ignore" I still get the shape of the UV pattern repeated all over the garment. Maybe something has changed?
  • lilweeplilweep Posts: 2,877
    edited June 2023
    shaders typically dont change uv.
    just dont change the tiling when applying shader
    Post edited by lilweep on
  • GordigGordig Posts: 10,811
    Applying a shader doesn't affect the UV. The issue you're experiencing is tiling, which can be done through the Image Editor or Layered Image Editor, I don't remember which one, for an individual map, allowing you to reset the tiling for the surface as a whole.
  • marblemarble Posts: 7,500
    Yeah, when I tried to adjust the tiling in the surfaces tab it just made things worse.
    I'll take a look at the Image Editors.
    Applying tiling on the surface affects the entire surface; tiling using the appropriate editor tiles only that map.
