After installing some new content , saved characters/models changed
Hello everyone , i am a visual novel dev that has been using dev for about 4 months ish now , yesterday i installed some assets and that resulted in all my saved created models / characters being morphed , I looked the solution up for this and did find a fix for my genesis 8 / 9 and 8.1 chracters , it was some chracter that's morph was auto applied , I went into parameters naturally as per the page suggested and just uninstalled those files , Now my gen 9 and 8 and 8.1 are fixed and it was easy to do because i could literally saw the hidden morph that was set to 100 instead of 0 and caused it
However i checked today again and realized my gen 3 models had this issue too , now unlike the previous fix I've tried hidden view , currently used and everything and there is no other character morph at all , any way to fix this?
  • Richard HaseltineRichard Haseltine Posts: 112,003
    Load the base figure - unfortunately Genesis 3 doesn't have a DevLoad version, as I recall - and use Edit>Figure>Zero>Zero Figure Shape, then Edit>Figure>Memorise>Memorise Figure Shape, then File>Save As>Support Assets>Save modified Assets; in the dialogue box make a note of what is listed as being saved - some of those will be changes you don't want to keep, but if you see character names they are probably the problem. Cancel the dialogue,  to make sure you don't save unwanted changes, then use the list of things it wanted to change to find and fix or remove the problems.
