X-Fashion Sexy Kimono - Material 06 Error (+fix)
AstrafelAstrafel Posts: 224
https://www.daz3d.com/dforce-x-fashion-sexy-kimono-for-genesis-8-females
While I'm loving the overall design of this kimono, I have discovered an error with one of the material sets and thought I'd mention it here in case it is of help to xtrart-3d or anyone else.
XF-Sexy Kimono mat06 has the wrong Top Coat Color image files from mat03 causing it to render like material 03 instead of expectedly as seen in both the preset icon and textured view of material 06. Material 10 has the same pattern as 06 in different colors yet the correct Top Coat Color setting.
While this seems easy to rectify, I don't know if it is important enough to get an update. If anyone else is not seeing this error, please, let me know as that would likely mean it's something local on my end.
Here's my current fix:
  1. go to the Surfaces pane
  2. highlight Base Kimono Mat and Bow Mat
  3. click the Top Coat Color image icon
  4. select Browse...
  5. select the correct XF-Floral Kimono D06 image file
note: I've noticed that the bow material is still a strange reddish violet rather than what seems like black in the preset icon and image texture file. That may indicate that there are other incorrect settings. This can at least be easily changed by using the bow and bow lining presets.
Post edited by Astrafel on
  • Richard HaseltineRichard Haseltine Posts: 111,247
    Please report this as a possible product issue, via a Techncial Support ticket.
  • AstrafelAstrafel Posts: 224
    Thanks for the response. I've submitted the ticket as directed.
