I need to make him blink and talk
friends, i really need your help with this (sorry if that guestion seems stupid to you)
i have made a character using headshop plugin
now i need to make it talk and blink (and like ideal move it to iclone to create an avi video with mask)
i have tried to make it in different ways but no luck
when i pass it to iclone (using 3dxchange) its moving with a whole body but not eyes and lips
tried to make lipsync in daz, but it still dont move (moving just head)
log file sais
Mimic warning: 'OpenLips' speech channel not found on 'head:2'
Mimic warning: 'Mouth F' speech channel not found on 'head:2'
Mimic warning: 'Tongue T' speech channel not found on 'head:2'
Mimic warning: 'Mouth O' speech channel not found on 'head:2'
Mimic warning: 'Tongue L' speech channel not found on 'head:2'
Mimic warning: 'Mouth CH' speech channel not found on 'head:2'
Mimic warning: 'Smile' speech channel not found on 'head:2'
Mimic warning: 'Open Smile' speech channel not found on 'head:2'
Mimic warning: 'Mouth M' speech channel not found on 'head:2'
Mimic warning: 'LBrowUp' gesture channel not found on 'head:2'
Mimic warning: 'RBrowUp' gesture channel not found on 'head:2'
Mimic warning: 'Blink Left' gesture channel not found on 'head:2'
Mimic warning: 'Blink Right' gesture channel not found on 'head:2'
Mimic warning: 'yrot' gesture channel not found on 'leftEye:2'
Mimic warning: 'yrot' gesture channel not found on 'rightEye:2'
Mimic warning: 'xrot' gesture channel not found on 'leftEye:2'
Mimic warning: 'xrot' gesture channel not found on 'rightEye:2'
Mimic warning: 'CTRLLipsPart' speech channel not found on 'head:1'
Mimic warning: 'CTRLMouthOpen' speech channel not found on 'head:1'
Mimic warning: 'CTRLBrowUpL' gesture channel not found on 'head:1'
Mimic warning: 'CTRLBrowUpR' gesture channel not found on 'head:1'
Mimic warning: 'CTRLEyesClosedL' gesture channel not found on 'head:1'
Mimic warning: 'CTRLEyesClosedR' gesture channel not found on 'head:1'
but i dont get how to improve it (actually i feel mysef a whole dumb but i dont get it at all)
  • Which figure are you using? Is it a figure, or just a static OBJ?
  • annamironova2007annamironova2007 Posts: 7
    edited October 2015
    its made from genesis male 2 + headshop + some body and face morpth
    here is my scene file in daz https://yadi.sk/d/JaIdm58kjTY4v
    and this one is fbx exported from daz
    Link removed
  • Richard HaseltineRichard Haseltine Posts: 111,842
    edited October 2015
    I've removed the link to the FBX version as that contains the actual geoemtry, which may not be distributed.
    The figure is Genesis 2 Male so the morphs should be available  -what you need is the .dmc configuration file that tells LipSync which morphs to use for which phonemes. Did you run the Genesis 2 - DMC install? If so you should be able to load the configuration file and that should clear the errors.
  • oh my! Genesis 2 - DMC  really made the lips move in daz!
    i'll have to check it in export to fbx
  • still cannt make it move in 3dxchange
    https://yadi.sk/d/s01sYWDfjTZbu (fbx without cloth and beard)
