Any Mac Users upgraded to El Capitan?
If so, any issues with DAZ products? I've been on Yosemite and all of the comments I've heard so far suggest it's well worth the upgrade, if it doesn't break any important stuff.
Also, does anyone else use Postworkshop 3? That's the one I'm most concerned about, since it appears the developers have completely lost interest in continuing development on it. I have both it and filter forge, and I much prefer PW3, even though it has some issues with certain .jpg files.
  • nemesis10nemesis10 Posts: 4,031
    Daz Studio seems to work just fine...
  • Updated on both my machines, all 3D applications I use work correctly so far.
  • Ah. That's good to hear! I might just start the install this weekend, then.
  • Works fine here too.
  • Cris PalominoCris Palomino Posts: 13,016
    All works well here, too.
  • BBrehmBBrehm Posts: 4
    Only Issue that is being disussed on other site forums that I'm aware of (And I am "experiencing") is that "IF" you are attempting to use the DSON Importer Plugin in Poser Pro 2014 (PP2014) to work with Genesis Characters in that App, after the Upgrade to OS X 10.11 (El Capitan), PP2014 will Crash on opening and generate the below Error Report. Again, this is an issue with the DSON Plugin and its presence in PP2014. <Might effect other versions of Poser Software as well> If you remove the Plugin from PP2014 the Application will start up without issue.
    Poser Pro 2014 Crash Report When using DSON Importer Plugin for DAZ Genesis under OSX 10.11 (El Capitan)
    Process:               Poser Pro 2014 [581]
    Path:                  /Applications/Poser Pro 2014/Poser Pro 2014.app/Contents/MacOS/Poser Pro 2014
    Identifier:            com.SmithMicro.PoserPro
    Version:               10.0.5.28925 (10.0.5.28925)
    Code Type:             X86-64 (Native)
    Parent Process:        ??? [1]
    Responsible:           Poser Pro 2014 [581]
    User ID:               501
    Date/Time:             2015-10-03 10:46:15.900 -0500
    OS Version:            Mac OS X 10.11 (15A284)
    Report Version:        11
    Anonymous UUID:        XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    Time Awake Since Boot: 6000 seconds
    System Integrity Protection: enabled
    Crashed Thread:        0  Dispatch queue: com.apple.main-thread
    Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes:       KERN_INVALID_ADDRESS at 0x00002e53555f6e78
    Exception Note:        EXC_CORPSE_NOTIFY
    VM Regions Near 0x2e53555f6e78:
        JS JIT generated code  0000273726401000-0000273726402000 [    4K] ---/rwx SM=NUL
        STACK GUARD            0000700000000000-0000700000001000 [    4K] ---/rwx SM=NUL  stack guard for thread 1
    Application Specific Information:
    objc_msgSend() selector name: length
    /Applications/Poser Pro 2014/Runtime/Python/addons/dson/libDzDSONIO.dylib
    Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
    0   libobjc.A.dylib                   0x00007fff9ccc8d5d objc_msgSend + 29
    1   QtCore                            0x00000001167d3131 getCFLocaleValue(__CFString const*) + 49
    2   QtCore                            0x00000001167d39ca QSystemLocale::query(QSystemLocale::QueryType, QVariant) const + 106
    3   QtCore                            0x0000000116817458 QLocalePrivate::updateSystemPrivate() + 790
    4   QtCore                            0x000000011681d8ab QLocale::QLocale() + 65
    5   QtCore                            0x000000011683f235 QString::toULongLong(bool*, int) const + 35
    6   QtCore                            0x000000011683f2e2 QString::toUInt(bool*, int) const + 20
    7   libDzDSONIO.dylib                 0x00000001160c2060 DzGuid::fromString(QString const&) + 970
    8   libDzDSONIO.dylib                 0x00000001160c27cd DzGuid::fromCString(char const*) + 41
    9   libDzDSONIO.dylib                 0x00000001160c0f58 __static_initialization_and_destruction_0(int, int) + 21211
    10  dyld                              0x00007fff6678df1b ImageLoaderMachO::doModInitFunctions(ImageLoader::LinkContext const&) + 265
    11  dyld                              0x00007fff6678e094 ImageLoaderMachO::doInitialization(ImageLoader::LinkContext const&) + 40
    12  dyld                              0x00007fff6678a6cd ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 305
    13  dyld                              0x00007fff6678a662 ImageLoader::recursiveInitialization(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 198
    14  dyld                              0x00007fff6678a553 ImageLoader::processInitializers(ImageLoader::LinkContext const&, unsigned int, ImageLoader::InitializerTimingList&, ImageLoader::UninitedUpwards&) + 127
    15  dyld                              0x00007fff6678a7c3 ImageLoader::runInitializers(ImageLoader::LinkContext const&, ImageLoader::InitializerTimingList&) + 75
    16  dyld                              0x00007fff6677feb0 dyld::runInitializers(ImageLoader*) + 89
    17  dyld                              0x00007fff66787118 dlopen + 555
    18  libdyld.dylib                     0x00007fff980d279c dlopen + 59
    19  org.python.python                 0x000000010199c85f _PyImport_GetDynLoadFunc + 303
    20  org.python.python                 0x000000010197f044 _PyImport_LoadDynamicModule + 132
    21  org.python.python                 0x000000010197d33f import_submodule + 383
    22  org.python.python                 0x000000010197d84a load_next + 234
    23  org.python.python                 0x000000010197db9e PyImport_ImportModuleLevel + 430
    24  org.python.python                 0x000000010195c483 builtin___import__ + 131
    25  org.python.python                 0x00000001018af5e2 PyObject_Call + 98
    26  org.python.python                 0x000000010195d5f7 PyEval_CallObjectWithKeywords + 87
    27  org.python.python                 0x0000000101961c78 PyEval_EvalFrameEx + 13256
    28  org.python.python                 0x0000000101965d29 PyEval_EvalCodeEx + 2137
    29  org.python.python                 0x0000000101965e46 PyEval_EvalCode + 54
    30  org.python.python                 0x000000010197a230 PyImport_ExecCodeModuleEx + 208
    31  org.python.python                 0x000000010197b4a2 load_source_module + 722
    32  org.python.python                 0x000000010197ca4f load_package + 463
    33  org.python.python                 0x000000010197d33f import_submodule + 383
    34  org.python.python                 0x000000010197d84a load_next + 234
    35  org.python.python                 0x000000010197db5b PyImport_ImportModuleLevel + 363
    36  org.python.python                 0x000000010195c483 builtin___import__ + 131
    37  org.python.python                 0x000000010196402d PyEval_EvalFrameEx + 22397
    38  org.python.python                 0x0000000101964ebe PyEval_EvalFrameEx + 26126
    39  org.python.python                 0x0000000101965d29 PyEval_EvalCodeEx + 2137
    40  org.python.python                 0x0000000101965e46 PyEval_EvalCode + 54
    41  org.python.python                 0x000000010198ab6e PyRun_FileExFlags + 174
    42  org.python.python                 0x000000010198ae29 PyRun_SimpleFileExFlags + 489
    43  com.SmithMicro.PoserPro           0x0000000100200ddd PEPythonEngine::DoScript(BPath const&, char const*, bool) + 1277
    44  com.SmithMicro.PoserPro           0x00000001002bc9bc PUIApp::InitPython() + 300
    45  com.SmithMicro.PoserPro           0x00000001004cf8dc wxPoserApp::CreatePalettes() + 3388
    46  com.SmithMicro.PoserPro           0x00000001004cd2ae wxPoserApp::OnInit() + 7806
    47  libwx_osx_cocoa-2.9.1.0.0.dylib    0x0000000102d4fc68 wxApp::CallOnInit() + 36
    48  libwx_osx_cocoa-2.9.1.0.0.dylib    0x0000000102c6c79c wxEntry(int&, char**) + 76
    49  com.SmithMicro.PoserPro           0x000000010031b759 main + 377
    50  com.SmithMicro.PoserPro           0x0000000100002344 start + 52
    Thread 1:: Dispatch queue: com.apple.libdispatch-manager
    0   libsystem_kernel.dylib            0x00007fff8f40b0a2 kevent_qos + 10
    1   libdispatch.dylib                 0x00007fff8c1a41ad _dispatch_mgr_invoke + 216
    2   libdispatch.dylib                 0x00007fff8c1a3e15 _dispatch_mgr_thread + 52
    Thread 2:
    0   libsystem_kernel.dylib            0x00007fff8f40a78a __workq_kernreturn + 10
    1   libsystem_pthread.dylib           0x00007fff92bed58c _pthread_wqthread + 1283
    2   libsystem_pthread.dylib           0x00007fff92beb375 start_wqthread + 13
    Thread 3:
    Thread 4:
    Thread 5:
    Thread 6:
    0   libsystem_kernel.dylib            0x00007fff8f40a2b2 __semwait_signal + 10
    1   libsystem_c.dylib                 0x00007fff90f93a75 nanosleep + 199
    2   libc++.1.dylib                    0x00007fff9b0ba020 std::__1::this_thread::sleep_for(std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000000000l> > const&) + 75
    3   com.apple.JavaScriptCore          0x00007fff8fa90a8b bmalloc::Heap::scavenge(std::__1::unique_lock<bmalloc::StaticMutex>&, std::__1::chrono::duration<long long, std::__1::ratio<1l, 1000l> >) + 155
    4   com.apple.JavaScriptCore          0x00007fff8fa906e4 bmalloc::Heap::concurrentScavenge() + 68
    5   com.apple.JavaScriptCore          0x00007fff8fa92c6a bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>::entryPoint() + 90
    6   com.apple.JavaScriptCore          0x00007fff8fa92c09 bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>::pthreadEntryPoint(void*) + 9
    7   libsystem_pthread.dylib           0x00007fff92bed9b1 _pthread_body + 131
    8   libsystem_pthread.dylib           0x00007fff92bed92e _pthread_start + 168
    9   libsystem_pthread.dylib           0x00007fff92beb385 thread_start + 13
    Thread 7:: JavaScriptCore::Marking
    0   libsystem_kernel.dylib            0x00007fff8f409f5e __psynch_cvwait + 10
    1   libsystem_pthread.dylib           0x00007fff92bee73d _pthread_cond_wait + 767
    2   libc++.1.dylib                    0x00007fff9b07b68f std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 47
    3   com.apple.JavaScriptCore          0x00007fff8f46181b JSC::GCThread::waitForNextPhase() + 171
    4   com.apple.JavaScriptCore          0x00007fff8f461668 JSC::GCThread::gcThreadMain() + 88
    5   com.apple.JavaScriptCore          0x00007fff8f456f62 WTF::threadEntryPoint(void*) + 178
    6   com.apple.JavaScriptCore          0x00007fff8f456e8f WTF::wtfThreadEntryPoint(void*) + 15
    Thread 8:: JavaScriptCore::Marking
    Thread 9:: JavaScriptCore::Marking
    Thread 10:: JavaScriptCore::Marking
    Thread 11:: JavaScriptCore::Marking
    Thread 12:: JavaScriptCore::Marking
    Thread 13:: com.apple.CFSocket.private
    0   libsystem_kernel.dylib            0x00007fff8f40a222 __select + 10
    1   com.apple.CoreFoundation          0x00007fff9e88229a __CFSocketManager + 762
    2   libsystem_pthread.dylib           0x00007fff92bed9b1 _pthread_body + 131
    3   libsystem_pthread.dylib           0x00007fff92bed92e _pthread_start + 168
    4   libsystem_pthread.dylib           0x00007fff92beb385 thread_start + 13
    Thread 14:
    2   com.SmithMicro.PoserPro           0x00000001006ad79b PUIWXFLC_ScanFolderPopThread::DoRepeatedly() + 107
    3   SMArtSkinBase.dylib               0x00000001039609ae sThreadStarter(void*) + 110
    4   libsystem_pthread.dylib           0x00007fff92bed9b1 _pthread_body + 131
    5   libsystem_pthread.dylib           0x00007fff92bed92e _pthread_start + 168
    6   libsystem_pthread.dylib           0x00007fff92beb385 thread_start + 13
    Thread 15:
    1   libmongoose.dylib                 0x0000000102bd8535 master_thread + 405
    Thread 0 crashed with X86 Thread State (64-bit):
      rax: 0x00002e53555f6e60  rbx: 0x00007fff5fbf71d8  rcx: 0x0000000000000007  rdx: 0x00007fff7e3f8030
      rdi: 0x000000010c5f5810  rsi: 0x00007fff9ec1ab94  rbp: 0x00007fff5fbf7170  rsp: 0x00007fff5fbf7138
       r8: 0x0000000000000040   r9: 0x000000010425d3e0  r10: 0x00007fff9ec1ab94  r11: 0x00002e53555f6e60
      r12: 0x00007fff5fbf7590  r13: 0x00000001163b4660  r14: 0x00007fff5fbf71d8  r15: 0x000000010c5f5810
      rip: 0x00007fff9ccc8d5d  rfl: 0x0000000000010206  cr2: 0x00002e53555f6e78
    Logical CPU:     0
    Error Code:      0x00000004
    Trap Number:     14
  • bytescapesbytescapes Posts: 1,932
    The mention of "STACK GUARD" makes me wonder if it's running up against the new System Integrity Protection system (and the trace confirms that SIP is turned on). A cursory glance at the info in the trace suggests that it's blowing up in something that does Javascript just-in-time compilation, which I could well imagine might do some edgy stuff that would get SIP upset.
    I haven't installed El Capitan yet, but I understand that SIP can be switched off. Worth turning it off and seeing if the DSON Importer still blows up?
  • ScavengerScavenger Posts: 2,677
    Anyone know if the Open CL/Gl issues Reality 4.1 were talking about get resolved?
    I saw Paolo stating he was having troubles with El Capitan compatibility today.  I don't use Reality, so not sure what the issues were.
    Hmm.. I'll have to dig up his commentns.
  • StratDragonStratDragon Posts: 3,290
    It's possible the 10.11 issue Paolo was reporting are the OpenCL tools Apple promised would be fixed are not fixed at this time in 10.11.0, or maybe they are fixed as far as Apple is concerned and that's the best we can expect. Keep in mind the Intel CPU in your mac is very Windows capable if you thinking of smacking that laptop off the balcony.
  • OldminerOldminer Posts: 135
    Upgraded and all works OK, except occasionaly on opening an existing file the system tries to open another type file (tiff, jpg, png and even a hdr) however if you click on the cancel button 3 or 4 times it will go ahead and open the .car! Don't know if this is a bug or if I need to change something in the system prefs.
  • mambanegramambanegra Posts: 601
    edited October 2015
    Apaprentl Filter Forge 4 (the app, no clue about the plugin) doesn't run at all in El Capitan. Crashes immediately upon startup. At least for me. DS seems fine. I haven't tried rendering anything in PP2014, but it opened fine once I installed downloaded flash. But, I haven't tried loading any genesis characters in almost a year in poser. It was too slow to bother with, IMHO.
    Also, for those who happen to be using PostWorkshop, it seems to run just fine. If you like making your stuff look "Sketchy" I think PW is better than Filter Forge. But, I haven't spent enough time with FF to know if it has the rich potential and the filters available for download just don't reflect that.
    (Edited to say FF did work until I tried to save, then it crashed again, since then it no longer opens.)
    Post edited by mambanegra on
  • vex3dvex3d Posts: 130
    Running El Cap and DS 4.8, haven't had a moment's problem. Poser, on the other hand, doesn't like to open the joint editor without a CTD.
    I have worked in both Filter Forge 4 and 5 with no hiccups in El Capitan.
  • PixelboyPixelboy Posts: 32
    edited October 2015
    DAZ has now a real full screen mode since el capitan was installed. Nice
    Post edited by Pixelboy on
