Geoshell and Geograft
I use a wet skin geoshell and a breast geograft.
The problem is the wet skin geoshell make the geograft white.
If the shell of the wet skin for geograft turned off, the wet on the breast is gone.
Is there a solution for this?
  • crosswindcrosswind Posts: 10,356
    edited June 2023
    I guess you just use Breastacular or some other grafts e.g. Lifelike boobs. Pls check this thread in which I posted the steps... https://www.daz3d.com/forums/discussion/comment/8183651/#Comment_8183651
    The process should be the same no matter you use a tattoo geoshell, wet geoshell or some exotic geoshells, etc.
    Post edited by crosswind on
  • LeanaLeana Posts: 13,650
    Assuming the geograft uses the same UVs as the base figure and not some custom ones, try copy/pasting the surface settings from a nearby geoshell surface (one corresponding to the torso of figure) to the geoshell surface corresponding to the geograft
    Note: depending on what base shader the wet geoshell uses, you may need to apply that base shader to the target surface first so the settings paste correctly.
