File acting stupid ...
I never know what I am looking at when trying to figure out what is wrong with a file, so I'm hoping ya'll can help.  Every time I try to either open or merge the file, it tells me 'the following items can't be loaded', then Daz (4.7) crashes.
From past experience, I know the log file notes what's wrong, so I deleted my log file then tried again so the file would only represent what this particular problem is.
Then, I tried to open the file again, after deleting the last log file, and it loaded like this (attached).
Any help will be appreciated.
1366 x 768 - 160K
txt
txt
this is where it crashed a few times - log.txt
589K
txt
txt
this is the latest attempt - log.txt
1M
  • EtriganEtrigan Posts: 603
    edited September 2015
    You have your "Rule of Thirds" filter on your camera.
    I'm not sitting in front of DS at the moment, but the rule of thirds add on is in a drop down menu in the top bar. You can toggle it on/off.
    Post edited by Etrigan on
  • And that's causing the problem? I always have it on, lol.
    Hmm, that's what it looked like to me. Then I looked at your log files.
    But, I'm also seeing this line in your second startup of DS
    "cannot be loaded because it requires a newer version of DAZ Studio.Make sure that you have the latest version of DAZ Studio installed. dzoptitexclothcontrol.dll"
    Your first startup had a lot of "can't find" statements.
    so, I'm no longer sure :)
    Did you open a ticket and give them those log fiies? I'm seeing a lot of warnings and missing components. What is the SDK doing? Have you installed a beta plugin?
  • I haven't done anything. I hade the file and for whatever reason now it's loading all white.
  • Also ... what up with the foreign letters?
    I'm not seeing foreign letters in either your program window or the text files (attached).
    If you are, there's a greater issue than DS, methinks.
    Have you done a hard reboot (shut down the computer and start from power-up)?
  • No ... should I?
    Ah! I see them
    Not sure. That should be a tool tips line IIRC.
  • I think language settings got changed somehow :( How do I change them back?
    Control Panel
    Region and Language Settings
    I use Win 7 at work, so the exact text may vary.
  • IceCrMnIceCrMn Posts: 2,334
    I was looking through that log file you uploaded,,good job btw :)  ,,,and I see what might be a cause for the crashing , not sure about the change in localiztion yet)still looking)
    C:\Program Files\DAZ 3D\DAZStudio4\plugins\dzautoriggerbasic.dll cannot be loaded because it requires a newer version of DAZ Studio.Make sure that you have the latest version of DAZ Studio installed.
    C:\Program Files\DAZ 3D\DAZStudio4\plugins\dzirayrenderer.dll failed to load. Cannot load library C:\Program Files\DAZ 3D\DAZStudio4\plugins\dzirayrenderer.dll: The specified procedure could not be found.
    C:\Program Files\DAZ 3D\DAZStudio4\plugins\dzoptitexclothbasic.dll cannot be loaded because it requires a newer version of DAZ Studio.Make sure that you have the latest version of DAZ Studio installed.
    ...looks like your plugins got updated but your Studio didn't.
  • I don't want to update studio, lol ... I just got comfortable with 4.7, lol.
    Since I doubt your plugins can be rolled back. I'm betting it's time to learn 4.8. You won't find too many differences IMO.
  • Ugh! I really wish Daz would quit interfering in my work schedule by forcing me to relearn software!
