Chroft Apartment Open Plan Living - Open Bedroom Door
http://www.daz3d.com/chroft-apartment-open-plan-living
I have this product and there doesn't appear to be a morph on the doors. The doors don't seem to be separate objects either. They appear to be the same model as the walls and ceiling. Some of the promo shots on the page above show the bedroom door open, but some show it closed as well. Is there some method for opening and closing the door that I don't know about?
Also, is the bathroom set meant to fill out the empty space in this plan? I have the same problem with the doors in that respect as well since there isn't a way to hide or open the bathroom door either if you put the separate bathroom product in this apartment.
Maybe I just need to get the full Chroft Apartment Complex since it says the doors can open and close. I didn't think I would need it though since I only want to show the interior of a single apartment.
Any help by anyone who has experience with this product is appreciated. I am currently working on a conversion to Iray for it and it looks great in Iray. The lighting and atmosphere that Iray can achieve just really makes this product pop.
    Greetings,
    The second-to-last untextured view promo seems to show the bedroom door open, as you noted, and the file list clearly includes four door-open morphs.
    Oddly enough I don't own it, so I can't say for sure, but I'm going to guess that there's some sort of 'base' object that might have the morphs on it?  Similar to how some cars have wheel-turn morphs on the base object, rather than on the wheels, or something like that, maybe the doors have to be opened from some higher level object..
    --  Morgan
  • Thanks for seeing those morphs in the file list. I hadn't thought of checking there. Here is what I found now that I know those morphs exist. There is a "Set" file called "Chroft Apartment OPL Area" that loads all of the furniture and the surrounding room. I was using this set. That version of the walls of the apartment does not have morphs for the doors, which does seem like a mistake.
    The separate set called "OPL Apartment Room" only loads the walls, ceiling, floor, etc. and not the furniture. This set has the morphs for opening the doors. I can just delete the main apartment prop and substitute the other working prop into my scene.
    I think I am still going to start a ticket because this seems like an error that the PA should know about. Thanks again CypherFOX.
