How to turn off lights????
in New Users
I've tried every thing but cannot turn off the preview head lamp when I render an image.I get the lights set when I'm drawaing but when I render it all the lights come back on GRRRRR!
In the scene tab, select the camera you're using (the headlamps aren't a light feature, they're a camera feature). In the Parameters tab, click on Headlamp in the left column and change Headlamp Mode in the right column from Auto to Off.
Note that this can cause your entire scene to go black, depending on what kind of lights you have in the scene. Use <ctrl>-L to toggle Light Preview mode on or off and you'll be able to see everything again.
Also, depending on if you are using any preset lights, check the scene tab for Headlamp Blocker lights, some presets lights load with this and depending on your setup this will flood the scene so make sure they are deleted.
