spot light are giving shadows
shown in the image are spot lite settings and the shodows are pointed out
is there anyway that there can be zero shadows or dark shapes when using the spot lites?
1079 x 1461 - 879K
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,842
    not with iray
  • Richard HaseltineRichard Haseltine Posts: 112,049
    You have Preferences>Show Hidden Proeprties enabled in the option menu for the pane, the shadow settings are hidden in Iray since they do nothing.
  • VicSVicS Posts: 1,273
    I checked where you said and it does not have the check mark next to it means not enabled right?
    edited June 2023
    iray is a fully PBR renderer so all lights cast shadows
    3Delight and Filament you can choose to not enable shadows, likewise Octane render if you have the plugin can have shadows excluded on objects because it has non PBR options
    Ok thanks Wendy
    now I don't know about the headlamp on the camera and cannot check right now but it's possible that doesn't cast shadows and can actually be translated away from the camera
