Is there a way to set the hdri so it will not change any render settings?
 as far as I can tell.....
1-one set I have changes no settings
2-another changes only settings in tone mapping
3-another changes all the render settings back to the default
is there a way to make it any hdri will act like number 1 and change no render settings at all?
  • Richard HaseltineRichard Haseltine Posts: 111,738
    Save a Render Setings preset and uncheck everything but the map in the options dialogue. Also, though I can't recall which options you will get, holding down the ctrl key (cmd for a Mac) when loading a preset will usually give a dialogue that lets you make choices relating to the preset.
  • VicSVicS Posts: 1,273
    Thanks Richard
    cant find any option for map
    and wont unchecking everything not save all the settings i wanted saved?
    403 x 1804 - 280K
    Scroll down, you aren't yet showing the Environment group.
  • crosswindcrosswind Posts: 10,341
     Just check the map ~
    568 x 655 - 48K
  • lilweeplilweep Posts: 2,878
    I just made render presets for all my polyhaven HDRIs. Time consuming to set up but ultimately such a time saver compared to going into my folders to load a new HDRI each time.
    I realise you can drag and drop them into the environment map slot but thats not much faster.
