Daz 4.8
Can you run daz 4.7 & 4.8 on the same computer?
    You can have the general release and the public beta.
  • BradCarstenBradCarsten Posts: 856
    edited September 2015
    I don't think you can on windows AFAIK.
    I've got Daz running in linux in a windows emulator called wine, and that allows you to install any software in its own virtual machine, so they don't interfere with each other. Because of this I'm running 3 different version of Daz on the same Computer.
    There are ways to install widows twice on the same machine, and then choose which version you want to boot into- that is an extreme work around.
    Post edited by BradCarsten on
    The only recommended way is as Mike described above.
    You can have two different versions if you use two different bit depths though, say, 4.7 at 32 bit and 4,8 at 64 bit (or vice versa)   That is the only way that I know of.
