Where is Photoshop Bridge?
I'm using Daz 4.8 pro (64 bit) and the install went fine (as far as I know) but no sign of 3D Bridge in the "about installed plugins" list.
I know I'm a newbie, but I've tried everything I can think of. Is it a seperate plugin? Where can I find it to install?
Any advice would be appreciated.
It's part of DS
Thanks for the swift reply. Is there some way I can download it seperately? Everything else int he package is already on my system. I don't know why Bridge wouldn't be. :-(
You need to go to your Product library, select the bridge as shown by chohole in her image, and download it
It should be available to install in DIM (DAZ Install Manager) as well. It is only of any use if you have Photoshop CS5 or higher (some people say it can be run with CS4)
Inside DIM, you also need to have the path to Photoshop listed in the Applications tab (click on the Gear icon at the top right to see it)
Forget it! Found it deep in the DAZ 4.8 stuff!
Thanks for your patience!
