What could be causing many of my script files to stop working
kerrykerry Posts: 74
I've been having some problems with some of my script products
My newer purchases Genesis 3 and 8 to 9 pose converter and the Camera Magic series have examples attached with error msg (same in both cases) and the log file.
Also these older purchases are affected like:
Pin libraries
Ultra scatter pro
UV swap
Quiet a few more
MultiDress
Dial fusion
It's like a domino effect, one session in Daz it will be working I come back a few days later and it's not. Then something else next time.
That's how it feels but I don't know for sure if that's the reality of it since I don't use every product every time.
I'm not adjusting files, or moving anything around, only I ever use this laptop. With the older products, I figured some were just not working anymore but some of the newer stuff is less than a year old so I'm hoping It's just 1  problem that can solve them all.
The error message may say check the log but I can't tell how to fix it from the log, allI know is that it says the path is empty but i've not changed anything. Tried uninstalling and reinstally in hope it would install the right paths for affected products but to no avail.
I figured if I could get to the bottom of one it might be the same fix for the rest.
Can anyone please help?
I've not knowingly moved any files, it just happened suddenly
Post edited by kerry on
  • Richard HaseltineRichard Haseltine Posts: 111,348
    Please attach the whole log file, not justa  picture of part of it. What version of Daz Studio are you using (Help>About Daz Studio)?
  • kerrykerry Posts: 74
    edited May 2023
    File upload hangs while uploading.
    Try this instead.
    https://drive.google.com/file/d/1tq7nOiMh6RlN8yx1RUB43l0wl7gp_fDv/view?usp=share_link
    My version is 4.16 pro
    It's not the most up-to-date version I know but when I go to Daz Central which is what I'm always advised to do I uninstall reinstall and still end up with this version.
    My bet is on Onedrive being the culprit with the nested Content Library in there; "C:/Users/kerry/OneDrive/Documents/DAZ 3D/Studio/My Library/Renderosity Stuff", which is inside "C:/Users/kerry/OneDrive/Documents/DAZ 3D/Studio/My Library"
    Do you log in to Daz Studio?
    Show us your Content Libraries in Content Directory Manager (Edit->Preferences->Content->Content Directory Manager) with all the paths expanded.
    It's also possible that the scripts were written with a newer version of DS
  • richardandtracyrichardandtracy Posts: 8,029
    It may be useful to check if its a problem with the script engine or the file locations.
    You could try killing 2 stones with one bird & use a G8->G9 freebie pose convertor script to both check the script engine & do something you want to do at the same time. I know mine is dead simple, and has been tested on DS4.10 on, and can be got here: https://www.daz3d.com/forums/discussion/598316/g8f-m-pose-transfer-to-g9/p1 (There are other freebie G8->G9 scripts in the freebie forum too, but I really only keep track of my own).
    If that doesn't work, the script engine is stuffed in some way calling for a re-installation of DS. If that one does work.. it's probably down to file locations and auto deletion of files somewhere unexpected. That rather calls for re-installation of the Riversoft script in the right place.
    Regards,
    Richard
