Water Drops on skin turn to black in shadowy areas?
This is one of those Geoshells that make the skin look wet, but the droplets turn to black in more shadowy areas of the skin making it kinda look like a stubble.
Can't exactly go light up every shadowy area either.
If anyone has an idea let me know.
Thank u smiley
456 x 486 - 391K
  • Richard HaseltineRichard Haseltine Posts: 111,382
    That will happen with real water too - it needs something to relfect/refract.
    There's light all around the scene and an interior. I understand that the reflection will be slightly darker, but it should not be entirely black like in the image.
  • truemadscientisttruemadscientist Posts: 16
    edited May 2023
    OK,
    I've solved it by finally figuring out the right Surface settings.
    Base Color & Top Coat Color must be entirely white, Top Coat Weight set to 0.73, Base Bump set from 2.00 to 1.00. It's possible just adjsuting Base Bump or Top Coat Weight could be enough, but this works for sure.
    Edit: nvm that shit is not fixed
    Post edited by truemadscientist on
