Content Items not showing up in Daz3d studio
Have been using the DIM.  The content Items show up in the DIM and the metadata and thumbnail show up properly.
When I run the database update in Daz3d it seems to run fine, but all the content items listed in the DIM do not show up and are not available.
I tired search in Content manager and smart content nope... not there.
Any suggestions
    By database update do you mean installing PostgreSQL CMS?  Did you re-import metadata?
  • rampart_1576840087rampart_1576840087 Posts: 504
    edited September 2015
    Installed using the DIM.
    It shows up as installed in the DIM
    The metadata updates in DIM
    The thumbnail updates in DIM
    It is not present in Daz3d studio in either Smart content or content.
    The content is Communications Gear by nightshift3d
    http://www.daz3d.com/communications-gear
    Post edited by rampart_1576840087 on
  • There are no DAZ Studio format files in this item, Only CR2 and OBJ, so everything will be in the Content Library pane under Poser Formats
    If you find the entry in the Installed tab in DIM, right click, and select Show Installed Files, it will give you a list of clickable links to where the content is installed to.
