Log Iray Error
Szark
Does anyone know what this means.
WARNING: dzneuraymgr.cpp(261): Iray ERROR - module:category(IRAY:RENDER): 1.0 IRAY rend error: Degraining filter cannot be combined with "black pixel filter".
I can't even find the Black Pixel Filter
The two types of noise reduction are not compatible. One or all of the pixel filter choices will not cooperate with the degrain noise filter. You do not need or want the degrainer unless you are intentionally stopping the renders before full convergence. Because you're stopping early, the pixel filter choices are never actually invoked, as these come into play as the render progresses.
If you're looking for the best renders, turn Noise Filter Enable to Off, and allow your renders to complete.
OK cool I didn't know that, thank you Tobor. It is one in the DAZ3D Advanced Render setting preset. I did turn it off and the error went. I generally leave the render to finish anyway so good to know.
