DS crashing PC during Iray Renders
Dark-Elf
Hi guys & gals, I'm hoping someone can help me please?
Whenever I run an Iray render, it gets to the end of the render and then my system turns off.
I can render fine in 3Delight but when trying to render off my new character in Iray, this happens every time. I had been able to get a few reasonable renders, though they weren't very high quality. And now I can't render using Iray at all :(
Any suggestions please?
It is when it gets to the end, you are sure? Are you using the GPU or only the CPU? What GPU do you have? Are the drivers up to date, and has it recently been updated?
yep, sat and watched it tonight using a clean scene, a different character, clothes, hair and lights. I have to use CPU only as I do not have an nvidea graphics card. I think the drivers are up to date, nothing has changed recently that I know of.
GPU is Asus R9 270X DirectCU II TOP 4GB GDDR5 Dual DVI HDMI DisplayPort PCI-E Graphics Card
It will also do it if the render is over 60% done and I cancel the render too :(
OK, go to C:\Users\YOU\AppData\Roaming\DAZ 3D\Studio4, open the log.txt file and paste the last hafl-dozen or so lines here. (AppData is hidden by default - depending on your version you may need to go to the Folder Options applet or use the option on the ribbon bar to see it.)
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Updating environment.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Updating lights.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Updating object flags.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Updating caustic portals.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Updating decals.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Using batch scheduling, architectural sampler disabled, caustic sampler disabled
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Initializing local rendering.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Rendering with 1 device(s):
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : CPU (6 threads)
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Rendering...
Iray INFO - module:category(IRAY:RENDER): 1.3 IRAY rend info : CPU (6 threads): Scene processed in 47.417s
Iray INFO - module:category(IRAY:RENDER): 1.3 IRAY rend info : CPU (6 threads): Allocated 30 MB for frame buffer
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00001 iterations after 53.804s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00002 iterations after 60.059s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00003 iterations after 66.338s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00004 iterations after 72.872s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00005 iterations after 79.074s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00006 iterations after 85.686s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00007 iterations after 92.214s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00008 iterations after 98.825s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00009 iterations after 105.005s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00010 iterations after 111.294s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00011 iterations after 117.982s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00012 iterations after 124.278s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00013 iterations after 130.502s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00015 iterations after 143.368s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00017 iterations after 155.945s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00019 iterations after 168.238s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00021 iterations after 180.717s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00023 iterations after 193.705s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00026 iterations after 212.214s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00029 iterations after 231.626s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00032 iterations after 250.286s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00035 iterations after 268.874s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00039 iterations after 294.613s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00043 iterations after 319.425s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00048 iterations after 352.010s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00053 iterations after 384.527s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00058 iterations after 417.057s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00064 iterations after 455.913s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00071 iterations after 499.188s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00078 iterations after 544.429s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00086 iterations after 593.804s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00095 iterations after 649.533s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00105 iterations after 713.863s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00116 iterations after 781.911s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00128 iterations after 858.841s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00141 iterations after 938.632s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00156 iterations after 1030.429s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00172 iterations after 1132.764s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00190 iterations after 1243.182s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00210 iterations after 1365.972s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00232 iterations after 1506.531s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00255 iterations after 1647.653s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00281 iterations after 1806.438s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00310 iterations after 1983.730s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00342 iterations after 2187.779s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00376 iterations after 2395.450s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00414 iterations after 2627.954s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00456 iterations after 2885.142s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00503 iterations after 3172.107s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00549 iterations after 3452.839s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00594 iterations after 3739.093s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00640 iterations after 4020.404s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00683 iterations after 4294.453s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00721 iterations after 4537.203s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00759 iterations after 4769.653s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00796 iterations after 4996.475s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00830 iterations after 5203.874s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00866 iterations after 5433.209s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00899 iterations after 5635.168s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00933 iterations after 5843.194s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00965 iterations after 6039.082s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 00998 iterations after 6241.000s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 01029 iterations after 6438.900s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 01053 iterations after 6586.183s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 01072 iterations after 6703.371s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 01088 iterations after 6801.888s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 01100 iterations after 6875.909s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 01110 iterations after 6937.922s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 01118 iterations after 6987.316s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 01124 iterations after 7024.661s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 01129 iterations after 7055.705s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 01133 iterations after 7080.641s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 01136 iterations after 7099.260s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 01139 iterations after 7117.946s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 01141 iterations after 7130.601s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 01143 iterations after 7142.988s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 01144 iterations after 7149.291s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 01145 iterations after 7155.499s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 01146 iterations after 7161.883s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 01147 iterations after 7168.477s.
Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Received update to 01148 iterations after 7174.650s.
So, the log file stops before the end of the render - that's interesting. Does it crash if you just plunk a cube promitive in an otherwise empty scene? If so, one possibility that occurs to me is that it is having trouble accessing the temp folder to write the render - go to Edit>Preferences and change the location of the temp folder, then try rendering again.
well, I tried this after changing the temp file and it worked. So I'm going to try a character again and see what happenes :)
ok, so I managed to do a render using a figure, basic settings. I wanted to up the quality so I turned up the max time to 3 hours from 2 and it shut down again. I have moved my temp folder and uodated my graphics driver to the most recent version available.
So, I'm going to try 1 more render at the default settings and see what happens. I'm really not sure about the quality of the attached as whether I could use it for promo purposes?
So, I've tried rendering again at the defult settings and that seems to work. But changing those settings in any way means the PC dies at the end of the render :(
Any ideas please?
