Is it possible to keyframe enabling and disabling of collision
I have an animation in Daz Studio but there are a couple of frames where the collision on the pants is causing problems because the figures hands are touching the pants.
I'd like to disable the collision on the pants for these frames only but I can't see how to set keyframes on them.
Is this possible?
Thanks
  • GordigGordig Posts: 10,802
    It's theoretically possible to animate collidability through a script, but a much better approach is just to tweak the animation to remove the collisions.
  • crosswindcrosswind Posts: 10,251
    Not possible natively as Smoothing Modifier / Collision are constant properties... You either move the hand on the frames or... if you have Mesh Grabber, drag the pants a little bit and create a morph, then tweak the morph's value on the frames...
  • That's a shame, but thanks for the answers.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,510
    you could use an invisible in render conforming collider like a bodysuit without gloves
