Help with No_Suit for G3??
Can someone give me an idea how to use the No-Suit product?  I see the morph dials.  I set them at 100% and apply the materials.  It just looks like V7 has a mostly transparent layer covering her.  How do I make it actually look like clothing?
  • fixmypcmikefixmypcmike Posts: 19,735
    Is this in the Viewport, or after rendering?
  • nicsttnicstt Posts: 11,715
    edited September 2015
    Load the no-suit figure from the clothing section.
    if you want to apply vic7 to it, select the no-suit figure, then load the v7 character on to the existing no-suit figure; at this stage you could also apply any morphs required. (I've not discovered if there is a way to load no-suit on to an existing figure.)
    Go back to clothing, no suit; applying (as an example) the no suit1 allsuit mat.
    Doing it a different way might mean you have to manually add the lip textures and the eyes & around them; that took me a bit to fugure out, and is how I did the no-suit render I have in the gallery.
    If the above doesn't help, let me know and I'll try and make it clearer and include a couple of screenies.
    Post edited by nicstt on
  • tring01tring01 Posts: 305
    Helpful, thanks.
