where are the plants for Fairytale Collection -- Fairytale Story?
in The Commons
Today I bought Fairytale Collection -- Fairytale Story plus all the parts it said where required
- Multiplane Cyclorama
- Woodland Realm Playset Two
- Woodland Realm Playset One
- Millennium Environment
- to use in DAZ studio
- however I am unable to find the plants that the the promotion says should be "You will find these textured Props in the Fairytale Story' folder of your Props library" this folder i can not find.if I do a search for FTstoryplant I find a whole load of different plants but they are just the materials where are the actual plants these materials should be used on? I used DAZ install manager to download and install and tried installingg manually from the zip files i am confused about what I am doing wrong
I will take a look and see if i can give you detailed instructions. I am guessing they are placards in the props folder. (textures on flat planes or textures for the props in the props folder. I believe this is one i converted to studio but give me a bit to check it out
I can confirm with JGreen that the props are just flat planes that have textures plastered over theme.
They aren't actual plants.
Note that whenever you see these four items listed as "Required Products", it usually — but not always — means "any one or more of these", not "all of these". They're very old now, but they used to be standard background props that could have all sorts of add-on textures applied to them. I haven't actually used the Playsets much, I've got a lot more use out of the other two.
ok in DAZ Studio you will find the plants under millenium environment/FC Fairytale Story/Materials (these are already assigned in the scene files)
in Poser Props/FairytaleStory is the props. Again they are mostly applied to flat planes, as these sets weren't really more than just simple environments. If however you were wanting more realistic plants there are more in the store that are really plant models. but these were meant to give the "impression" of plants.
ok thanks I will look in the store for other plants the backgrounds still useful and cheap enough so no real loss there thanks for the help
