Add a Base Directory Suggestion
IceDragonArt
It would be awesome if you could move the remove all base directories farther down the list instead of directly under the add a base directory tab. Guess what i just spend the last half an hour doing? Yup, re adding all of my base directories because I was distracted and hit the wrong button. maybe do add a base directory then refresh and put the remove all directories button to the bottom of the list?
You can reorder directories in the Content Directory Manager - available from the Content Library pane option menu or Edit>Preferences' Content Library tab.
