Autofit G8.1F to G8F?
PtropePtrope Posts: 696
Is there a workflow - or a utility - that allows one to fit clothing intended for G8.1F to G8F? I didn't realize there was even an issue, since there is only a .1 version difference, but I'm trying to load one of Lali-K's bodystockings onto a G8F character, and it says the clothing is not intended for it - and it also does not offer G8.1 as the figure it was made for, so I have to use G3F, and of course the arms don't line up.
  • HavosHavos Posts: 5,703
    Edit the scene identification of the 8.1 clothing item and change Compatibility Base from Genesis 8.1 Female to Genesis 8 Female.
    Then fit to G8F as normal and you should not get a pop-up.
  • GordigGordig Posts: 10,799
    It doesn't offer 8.1 as the donor figure because while 8.1 is backward-compatible with 8, 8 is not natively forward-compatible with 8.1. You could try the Scene Identification trick:
    1. Load the stockings without fitting to your G8
    2. With the stockings selected in the Scene pane, click the three-lined "hamburger" icon at the top-left of the Scene pane and go to Edit -> Scene Identification
    3. Change "Preferred Base" from G8.1F to G8F and hit Accept
    4. Fit the stockings to your G8F.
  • PtropePtrope Posts: 696
    Thanks! I'll give that a try!
  • takezo_3001takezo_3001 Posts: 2,041
    Also this is an excellent freebie to get your G3 poses to work with G8/8.1!
