Will Dforce Clothing Work On Victoria THREE ?
FauvistFauvist Posts: 2,291
Will Dforce Clothing Work On  Victoria THREE  (the pre-Genesis generation before Victoria 4) ?
Thanks
  • felisfelis Posts: 6,648
    If you can get her inyo Daz Studio. dForce do not care what it collides with.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,836
    well I Dforce all my legacy clothings on V3, A3 etc
    some falls apart as not welded but most work,
    the ones that break up  do it autofitting to duf figures too as need welding which I do sometimes do in Ultimate Unwrap3D as any other modeller I have will destroy the UV mapping
  • FauvistFauvist Posts: 2,291
    I can definitely get her into DAZ Studio!
    How do you turn off the conforming function of the dforce clothes?
    If you start from default pose, it doesn't matter if clothing are conforming or not, as it will simulate before the character do a pose where it would conform.
    But of course the clothing needs to be usable with dForce.
    I usually dial close fitted surfaces to 0 simulation (if it's welded that is) and just dforce the skirts, flounces etc
  • richardandtracyrichardandtracy Posts: 8,264
    edited May 2023
    I can confirm that Karanta's clothing for the V3 GND2 morph dForces quite well. Jim Burton's clothing for the V3 variant GV3 works too. Example below, both dresses dForced to drape a little better.
    You may need to tweak the coefficient of friction and fabric stretch to get it to work well, but much of it does work.
    If considering more modern clothing, you're more likely to get Genesis 3 clothing to fit than Genesis 8 due to the T pose start of simulation. Regards, Richard.
    Post edited by richardandtracy on
