Cthuloid tentacle posing dials?
vonHobovonHobo Posts: 1,715
edited May 2023 in The Commons
https://www.daz3d.com/cthuloid-for-genesis-8-male
This product states:
  • Individual and Group posing dials for tentacles
However, I cannot find these dials anywhere in the Parameters pane or the Shaping pane.​
Does anyone know where the tentacle posing dials are located?
I can't use the figure in the default pose because the tentacles just stick out like spokes on a bicycle tire (second image).
1000 x 1300 - 605K
684 x 669 - 258K
Post edited by vonHobo on
  • Faeryl WomynFaeryl Womyn Posts: 3,789
    edited May 2023
    Have you tried selecting the tentacles individually, then check to see if the dials show up, I have to do that sometimes with some items.
    It does say individual and group movements, so yes click on one and see what happens, not sure where you would find the group poses, unless you just click on various things to see if they show up in parameters.
    Post edited by Faeryl Womyn on
  • vonHobovonHobo Posts: 1,715
    edited May 2023
    Yes, I did try that, but I didn't see the dials even with the tentacles selected. So it's a mystery.
    OK. I found it. Thank you. It's the top level "Cthuloid Tentacles" you must select to access the posing dials, not the individual tentacles themselves.
    Spent half the evening trying to figure this out. So I will try to build my scene tomorrow instead. Urrrgghhh. frown
    Thank you for your help!
  • nemesis10nemesis10 Posts: 4,046
    I looked in the wiki for the product and it lists the tentacle shaping as a morph rather than a pose so go to the Shaping Tab, search for G8MCthuloid and see if you see the morphs:
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/All_Curl_Side/Side.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/All_Curl_Up/Down.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/All_Hang_Down.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/All_Twist.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/L1Curl_Side/Side.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/L1Curl_Up/Down.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/L1Hang_Down.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/L1Twist.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/L2Curl_Side/Side.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/L2Curl_Up/Down.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/L2Hang_Down.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/L2Twist.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/L3Curl_Side/Side.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/L3Curl_Up/Down.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/L3Hang_Down.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/L3Twist.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/L4Curl_Side/Side.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/L4Curl_Up/Down.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/L4Hang_Down.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/L4Twist.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/R1Curl_Side/Side.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/R1Curl_Up/Down.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/R1Hang_Down.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/R1Twist.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/R2Curl_Side/Side.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/R2Curl_Up/Down.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/R2Hang_Down.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/R2Twist.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/R3Curl_Side/Side.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/R3Curl_Up/Down.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/R3Hang_Down.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/R3Twist.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/R4Curl_Side/Side.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/R4Curl_Up/Down.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/R4Hang_Down.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/R4Twist.dsf
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/Raw Cthuloid-HD.dhdm
    • /data/RawArt/G8MCthuloid/Cthuloid Tentacles/Morphs/RawArt/G8MCthuloid/Raw Cthuloid-HD.dsf
    Thank you! Yes, I did find them (see above comment).
