Export a figure covered in hair as an OBJ (with hair included)
Does anyone know how to export Sasquatch figure as an OBJ so the hair is included? I can export the OBJ but it is just the figure.
Any ideas?
  • AscaniaAscania Posts: 1,856
    You can't. Why the obj file format nominally includes line objects that can be used for hairs no program actually implements it in a way that allows you to transfer hair (if it is implemented at all)
  • crosswindcrosswind Posts: 10,333
    edited May 2023
    Technically you can, generate Line Tessellation first in Viewport before export... but what's the purpose of doing so ?  If you wanna make some morphs for the fur and import them back to Ds, you'll never make it as they're all strand-based hair...
    554 x 1375 - 116K
    2560 x 1400 - 1M
    Post edited by crosswind on
  • GordigGordig Posts: 10,811
    Set line tesselation to 0 and the figure exports with the hair as splines/curves/whatever terminology you want to use. I do this all the time to convert dForce hair to C4D and Houdini's native hair systems.
  • coolhand71coolhand71 Posts: 11
    edited May 2023
    I'm looking to import it into another program where I can add stone textures like a statue. It would be great if he hair shape was there so it didn't look like a shaped ape.
    Maybe I export from Daz to Bender and then export again?
    Post edited by coolhand71 on
    edited May 2023
    Hmm~ you may try but such the fur may look not so good as a 'statue'. wink You need to set the Line Tesselation to 2 at least otherwise there'll be no 'face' on it,  then there'll be no fur with texture in Blender.
