Is there a way not to select the rotation, instead the body part in the posing pane when selecting?
When I select a body part, in the posing pane, it will automatically select rotation. Is there a way not to select the rotation, instead the body part ?
  • GordigGordig Posts: 10,811
    Which figure are you using? I've noticed that G3 Powerpose selects twist bones when present, but I don't know if that's true of G3 in the viewport as well, since I don't really use G3. Also, does this happen to ALL body parts, or just the body parts that have twist bones?
  • JamesJames Posts: 1,191
    G3 G8 G8.1
    All body parts behave similar.
  • crosswindcrosswind Posts: 10,330
    edited May 2023
    You meant: Select the 'body part' from the 'Dropdown List' in Posing pane?  If you don't wanna 'Rotation' to be selected (that's the default), just select 'All' or 'Transforms', etc.
    But also, not sure what you wanna do ...
    Post edited by crosswind on
  • Richard HaseltineRichard Haseltine Posts: 111,721
    Group selection, as long as it exists on the selected node, is persistent. But I am not at all sure what you are wanting.
    edited May 2023
    If I click a body part on viewport.
    The posing panel always highlight the rotation first.
    Meanwhile what I want is to be able to hightlight the body part first, so I can immediately use exisiting morphs.
    376 x 294 - 18K
    Post edited by James on
    There's no way to do that you want in current Ds version... as when the node changes, the selected item will lose focus... unless Daz modifies Ds application to realize such an 'feature'...
    If you have Pose Controls seelcted on the figure node then it will be selected on the bonde, if present. You could also select All and that will then stick regardless of selection (but may be a bit overwhelming on the figure node).
