Moved and renamed folders
I moved my DAZ folders to my other harddrive for a new PC, then I put them on my C drive on the new PC. However, now DAZ doesn't recognize the folder paths. When I load up my old scenes, it says the texture files are missing. I made and used a load of custom texture files for my scenes. I don't want to redo all my scenes and i can't remember what exactly I had named the folder my DAZ install was in. Is there a way to fix this?
Thanks
  • Richard HaseltineRichard Haseltine Posts: 111,315
    Were the missing files in a content directory when you aplied them initially? If so then, as long as it was a content directory inside another content directory, it shouldn't be an issue as long as the new location is correctly selected in daz Studio (the folder that holds the Runtime and Data folder). If not then the file will have the absolute path, if you correct it for the first file in response to the prompt any others with the same location should then be found and you can just resave. The exact name of the content directories does not matter.
