Texture Atlas Only Shows A Few Images
I can't seem to figure this out, but how come when I open the texture atlas only a few images show up in the list of images?
  • I don't think I have that issue. Is this only on certain models? Are you expecting it to show all textures in the scene, or only from the figure you have selected?
  • It seems to randomly happen. Have a figure selected, and sometimes it seems to load all the textures and other times it doesn't. Maybe I am doing something wrong when I open the texture atlas?
  • all the textures for what though?
    If you have a figure selected and i has no clothes TA will only load the base figures textures. If they have clothes or hair on them it will load those up too.
    If you select the hair only the hair would show up in TA.
    Or do you mean certain areas are missing? Like the head loads but the arms dont.
    Just trying to figure out what is missing.
  • Good a place as any to ask.  I must be a dummy  Texture Altas is listed as an installed plugin but I cannot find where to access it.  I don't have the "customise" option in my edit menu bar dropdown.
    Any suggestions anyone?  Thanks. Lx
    The HotKey for Customise is 'F3' try that and see if it appears.   If not, what Layout are you using?
    Texture Atlas is also on the 'Creator Tools' toolbar, but you may need to activate it first in the Customise menu.
    Hover over one of the tools at the top of your layout, and you should see a list of toolbars that are active.
  • stitlownstitlown Posts: 324
    Hey JimmyC... only just got around to playing with this, so thanks for the pointers.  Found it and added it to my tool bar.  Now just unsure what on earth it does for me.  I can see it lists the surfaces on a figure  but so does the surfaces tab.
    Cheers,
    Lx
