Can 'Show Asset in...' be added in Customization menu?
SnowSultanSnowSultan Posts: 3,832
Does anyone happen to know if this function, the "Show Asset in - Content Library > Mapped Folder" option that can be brought up by right-clicking on an item in the Smart Content panel, is available in the Customization menu? I checked the Content Library, Smart Content, and a bunch of other sections, but cannot find that particular selection. Thanks for any information.
342 x 195 - 30K
  • Richard HaseltineRichard Haseltine Posts: 111,350
    I can't immediately see it, no.
    officially confirmed, I'm afraid.
  • SnowSultanSnowSultan Posts: 3,832
    No problem, thanks for checking. I use it a lot because Smart Content just piles everything together in the product folder, but it's not that big of a deal to right click and find it. Appreciated.
    Yes, it's necessary with (almost) anything that relies on folder structure to show how a product should be used - which includes a lot of shader sets.
    Heh, yeah it's pretty much impossible to use with a pose collection that includes partial poses. Is there a particular reason why Smart Content can't recognize folders within the product installation, but still collects all of the files from within them?
    I don't think this is a techncial issue, it would just require that categories be assigned based on the folder structure of the product in these cases. However, the folder structure wouldn't always be useful so I guess there is no policy on when it should or shouldn't be used.
  • UtiltarianUtiltarian Posts: 77
    edited May 2023
    What do you mean by Customization menu? Do you mean the application's toolbar, which can be customized via Window -> Workspace -> Customize?
    If so, while I'll take Richard's word that the feature does not exist, you can instead create and pin a script to the toolbar which implements this functionality.
    Here's the code you would need:
    var paneManager = App.getInterface().getPaneMgr();var smartContent = paneManager.findPane('DzSmartContentPane');var tab = smartContent.getCurrentTab();var contentTab = tab.getProductAssetsView().getContentTab();var assets = [];if (contentTab.visible) {    assets = contentTab.getSelectedAssets();} else if (tab.inherits('DzFileContentTab')) {    assets = tab.getSelectedAssets();}if (assets.length > 0) {    var contentLibrary = paneManager.findPane('DzContentLibraryPane');    contentLibrary.showPane();    contentLibrary.browseToAsset(assets[0]);}
    Post edited by Utiltarian on
    These commands are avaialble in the Smart Content pane by right-click on a thumbnail - right-click is generally called a context menu, since its content depends on what is under the click.
    Do bear in mind that using undocumented features carries a very high risk that they will change in later versions.
    I understand that the commands are accessible through the UI, I was just offering OP a method of achieving what they wanted, assuming I correctly understood the ask.
    As for the undocumented feature, that's a fair point. Perhaps ChatGPT will be smart enough to auto-upgrade my scripts if/when the API changes. laugh
    Thank you Woofer, but I'll stick to right clicking rather than risk destroying Studio.  ;)
