Stonemason´s Skydock - invisible backdrop in Iray
chrbou2001
Having problems with the Skydock. When rendering in 3Delight there are no problems, but when rendering in Iray then the backdrops don´t show up, there is only black (also after changing the surfaces with Iray shaders).
Try reloading it but do not change the materials to Iray then render and see if that works.
for this to work in Iray you need to turn 'diffuse strength' up to 100 to see the backdrop
Thanks for the tip
