select an asset in content pane
Hello,
I have a little problem. I can't select the asset in the content pane
here is my code
var oPaneMgr = MainWindow.getPaneMgr();
var oPane = oPaneMgr.findPane("DzContentLibraryPane");
var oContainer = oPane.getSelectedContainer();
var azerty=oContainer.getNumAssets ();
oContainer.getAsset(0).select
but it does not work someone can help me
thanks
Post edited by ann0314 on
  • Richard HaseltineRichard Haseltine Posts: 111,852
    Is select a method (in which case it will need parentheses, with or without values) or a proeprty (in which case it needs to be assigned a value)? Remeber that undocumented features are subject to change without notice.
  • Thank you for your answer. I understand.
    I found an interesting function but I don't know what a Qstring or a Qliststring is.
    oPane.selectAssets(QString,QStringList)
    In general QName is the generic, Qt Script version of objects that Daz Studio generally implemets as DzName. QString is just a string object - presumably an identifier (e.g filename, perhaps) for the item to select. QStringList isn't in the DS scripting docs, but appears to be an object made of multiple strings searching for the (later, note) Qt docs https://doc.qt.io/qt-5/qstringlist.html
  • Thank you for your help
    it's beyond my skinny skills
    too bad
