After convert with Genesis 8 Cross-Figure Resource Kit
foxyfoxfurries
Hello :)
I converted some shoes with 100% female transfer but it looks bad on 100% so I wanted to change to 50% , When I try to change it again it says , I do it with this : Genesis 8 Cross-Figure Resource Kit [Documentation Center] (daz3d.com)
If you run the script a second time, you will get the following error: “The follow for this figure has already been made. Delete the property “FID_Genesis8Male” and re-run to recreate setup.” Select “OK” and see the Troubleshooting section below.
First, start over with a new scene. Since there are very few steps involved, this is a viable option.
Second, you will need to follow these steps:
Select the item in the Scene Tab.
On the Parameters pane menu, make sure to “Show Hidden Properties”.
In Parameters highlight “Hidden > Cross-Figure”.
R-Click any of the three properties listed and select “Edit Mode”.
R-Click each of the three and choose “Delete Selected Property”.
Re-run your script.
I did all of it but dident understand where I delete it I go to the hidden > cross figure but there I get lost lol xD
What it means and what I need to delete? and where can I find it?
Thanks! :)
NEVER MIND I succeed , Thank you all :)
