render issue
ok people it's been awhile since i've fiddeled around with daz (since version 2) so when i render in 4.8 it renders what's in the aux viewport not in the main viewport.what the heck am i doing wrong.thanks
  • fixmypcmikefixmypcmike Posts: 19,743
    Make sure the main viewport is active before you render.
  • MJWMJW Posts: 540
    Check which view you have chosen for the view at the time you set your render settings. I find that creating a camera helps no end. I usually try to create one in Perspective view in the position I want and make it to 'copy active view' because that is more or less where I want the angles. Then I revert to perspective for continuing changing the appearance and know that the original position of the camera is set. It shows which view you are using on the little grey cartouche at the top right of the window screen.
    339 x 281 - 89K
    679 x 508 - 159K
  • Make sure the main viewport is active before you render.
    @Fixmypcmike  how do you make the main viewport active?
    sounds like a good idea.never had to do all that in older versions of daz
  • SzarkSzark Posts: 10,634
    you should notice and faint orange outline around the Viewport when you click the edge of the Viewport with the mouse.
  • thanks you guys..been real helpful
