Basic Problems
I am having several problems/ and I can't get a response from technical support. Dirst, my Smart Cont had disappeared from the Smart Content Pane. How do I get it back ? Seconf. How do I get a realistic skin tone for Genesis 3/ Lastly, does anyone know the SKU for Genesis 3 ? Thanks
Sorry about the spelling. My eyesight is not gtreat.
Smart Content is controlled by the CMS (Content Management Service) which has to be running for it to work. Did you install PostgreSQL using DIM from your downloads, or a re you still using the older Valentina/CMS. Anyway, go to the drop-down menu in the Content Library pane, and select Content DB Maintenance, then 'Re-Import Metadata' and see if that works.
What is wrong with the skin tone on G3F, and what render engine are you using, Iray or 3Delight.
I am not sure that G3F has an SKU, it is only available through the G3F Starter Essentials.
http://www.daz3d.com/genesis-3-starter-essentials
SKU:21630
