Having trouble with victoria 4.2
connor.brigsconnor.brigs Posts: 5
edited January 2024 in Technical Help (nuts n bolts)
its already solved thanks.
Post edited by connor.brigs on
  • Richard HaseltineRichard Haseltine Posts: 111,475
    In which application? If Daz Studio are you using Power Loader (do you get a dialogue box, is there a a scroll icon on the character's thumbnail image)? How did you install the content? Have the morphs gone to the same content directory as the base figure?
  • Faeryl WomynFaeryl Womyn Posts: 3,779
    edited April 2023
    Richard this is that old problem of morphs not working, he has to run that thingy, DZCreate for V4 that comes with the files to get the morphs to work
    291 x 510 - 16K
    Post edited by Faeryl Womyn on
    PoswerLoader does the same job, but on the fly allowing customisation of what loads from amongst the installed products (DxCreateExPFiles adds in all installed ExP products automatically).
    That's what I thought as well, yet I still had to run that Dx in order to have my Gen 4 morphs work and I have the latest Daz (not beta).
    That is very odd, and not what I would expect.
    I think what Richard asked in his first post is relevant "How did you install the content?"
    Further, do you log in to DS?
    Hmm in my case that could be the problem, I don't log into Daz, it's offline and I manually install.
    edited April 2023
    That is better, logging in is needed only when one has made a concious decision to use DAZ Connect inside DS as ones primary means to install content
    Logging in to DS can cause DAZ Connect to install stuff and when it does, some products (scripts, older stuff...) will not work due to the location it uses for installation
    Post edited by PerttiA on
