Use dForce to Stretch Around an Object?
Is it possible to use dForce to simulate something like tape or plastic strentching around another object, like a box or cylinder?
  • Richard HaseltineRichard Haseltine Posts: 111,922
    You mean to animate the wrapping, or to achieve the effect in a still? The latter could probably be done with a sphere, torus, or cube using the Geometry Editor to remove all but a band around the middle, then applying a dForce modifier and using a value less than 1/100% for Expand/Contract to get it snug. Animating might be possible with a long strip of mesh, pinning it (0 simulation strength) at one end and using an animated primitive to control the wrapping, but I think if you wwant the effect of unspooling tape you'd have to add that in post by having a reel separately animated and masking out the actual simulating  strip where it projected beyond the reel.
  • Nyghtfall3DNyghtfall3D Posts: 817
    The latter.
    Thanks.
  • RGcincyRGcincy Posts: 2,864
    This tutorial shows cling wrap on a figure but not all the way around.
    Thanks,but I'm either dense or Daz moved stuff/relabeled it since that tut was posted.
    There are no simulation settings in the Surface pane when selected the Plane primitive or dForce Weight Modifier created, and I don't see an option for creating a "dynamic" dForce Modifier, only a Wind node or Weight modifier.
    It's not in the Create menui, it's applied to an existing model so it is in the Simulation Settings pane options menu or in Edit>Figure or Object>Geometry
    edited April 2023
    I never knew there was anything dForce-related in the Geometry Editor.
    Thank you.
    EDIT: From the post RG linked to, I don't see these options in the Simulations settings:
    c. In the Surface pane, set the Simulation parameters as follows:
    • Stretch, Shear, and Bend Stiffness
    • Buckling stiffness
    • Buckling ratio
    • Density
    All I see is this:
    368 x 265 - 14K
    Post edited by Nyghtfall3D on
    Those are in the Surface settings for the item once it has the dynamic dForce modifier in place.
  • lou_harperlou_harper Posts: 1,163
    Dforce Magnet should be the thing for it.
  • stem_athomestem_athome Posts: 526
    edited April 2023
    I was never able to get d-force to shrink(contract) onto an object correctly, certainly not for it to look like it is stretching around an object.
    Instead, for the exaple posted, I would expand the cylinder/object into the tape(object to be stretched).
    Quick example renders:-
    Before/after.
    800 x 400 - 198K
    800 x 400 - 218K
    Post edited by stem_athome on
