Can autofitted clothing be used in Poser?
I have Poser Pro 2014 w/ DSON importer. I'm not very comfortable in Daz Studio so I only use it for utility purposes. Like, autofitting clothing to Genesis would be an example of the sort of thing I would use it for, but with the intention of using it in Poser. In my first experiment with this, I converted a shirt from M4 to Genesis 2 male, saved it as a figure/prop asset in the folder Daz wanted to save it in, opened up Poser Pro to see if it worked. It wasn't accessible from my Library, so I found it and moved it to Runtime/Libraries/Character. Then the folder I had put it in was there, but (from a Poser standpoint) it was empty. There was no CR2, just a duf, which doesn't even show up in my library. The original shirt was in Poser format. Is it really not possible to convert something with autofit and use it in Poser, or have I just made a mistake?
Once converted and saved, it is no longer in Poser Native format...it is now a Studio native asset. To use that in Poser, you would need to use the Importer/generate your own Poser Companion files...
Get the free D3D DSON loader
I used that script, and it worked! Thanks! And I saved it to my library from Poser, and it loaded!
