Texture Tearing
This happens to me in renders with clothing fairly often. I can't nail down what the issue is... I think it may have something to do with subD?
Any help would be appreciated.
440 x 521 - 576K
  • PrefoXPrefoX Posts: 336
    texture compression?
  • GhostofMacbethGhostofMacbeth Posts: 1,777
    Poke through is what it looks like to me.
  • Leonides02Leonides02 Posts: 1,379
    That isn't the color of his skin, though?
    It went away when I matched the subD between the clothes and the body. I don't have to do that most of the time, though.
    I don't know what the outft is but it could be between layers of clothing or the surfaces of indivual pieces (interior and lining, for example).
  • JoeQuickJoeQuick Posts: 1,735
    I'd listen to Mac, he joined in 2003!
  • lilweeplilweep Posts: 2,879
    Well hide the character visibility and see if it goes away?
    Daz doesnt like overlapping geometry so if garment for some reason has doubled up geometry intersecting, that could be issue.
  • ArtiniArtini Posts: 10,996
    edited April 2023
    It happens to me quite often, while transferring clothes on the character to Unity.
    Usually, I just switch to another clothes in such cases.
    Wondering, how developers think - I mostly miss additional morphs to avoid/fix pokethroughs.
    Post edited by Artini on
  • If it's an under-layer of clothing, check the displacement parameter for all the materials. If it's much bigger on the under layer than the top layer, then that could be causing it. The way to solve it is set the max displacement distance for any & all under-layers as 0 and see if it has an effect.
    Regards,
    Richard
