Genesis 8.1 to Genesis 8 just shape convertion
martin36martin36 Posts: 185
edited April 2023 in The Commons
Hey guy,
Is there any way to convert G81. to G8? I am trying to export obj but when importing to morph loader I got warning geometry not match and it fail
Post edited by martin36 on
    G8.1 is G8, why don't you use G8.1?
  • martin36martin36 Posts: 185
    edited April 2023
    Because I am using old daz version (4.14) and some stuff won't work with newer version. I am planing upgrade but it will be in summer probably. So that's why and I am stuck as I have few characters 8.1 and I want to use them. Do you know how to? Just a shape, no skin etc...
    edited April 2023
    G8.1 can use G8 and G3 textures/skins with no problems and if the SubD is set at the same level as with G8, G8.1 is no different from G8.
    Edit; Sorry, forgot... One needs DS 4.15 for G8.1 to see G8 morphs and characters. Try testing you import/export settings first with G8, before trying the same with G8.1
    Post edited by PerttiA on
  • One other thought. I have occasionally had sliders for G8.1 characters appear in my G8 base character 'Shaping' tab. It'd be worth looking there to start, see if it's already been done for you.
    Regards,
    Richard
  • HavosHavos Posts: 5,704
    martin36 said:
    Hey guy,
    Make sure the character mesh resolution is set to base, and delete any eye lashes, eye brows etc before exporting.
    8.0 and 8.1 are the same mesh (only for the same gender of course), you should be able to import then use the morph loader. If you do use this method, you will lose any jcm corrections for that morph, so it is not the best way to go from 8.1 to 8.0, however the alternatives can be quite advanced, as you would likley need to edit the dsf files, which is non-trivial.
    Regards,
    Richard
    I checked it first. Tried even move files to motrph folder but no luck
    Havos said:
    martin36 said:
    Hey guy,
    Ok I will try it now. Thank you for help guys
    edited April 2023
    martin36 said:
    Havos said:
    martin36 said:
    Hey guy,
    And btw what I should uncheck in the popup window when I export? Leave it default for Daz?
    martin36 said:
    martin36 said:
    Havos said:
    martin36 said:
    Hey guy,
    Attach a screenshot of the dialoque, not at home with DS atm.
    Ok I am attaching screenshot below:
    902 x 962 - 120K
    Uncheck everything, and when exporting, do not forget to set the figure to base resolution, posed in default A-pose, any and all attachments (eylashes, eyebrows, etc.) removed
  • BejaymacBejaymac Posts: 2,007
    Knowledge is a wonderfull thing, a two minute job for me, turns into a panic inducing nightmare for most of the rest of you.
    Well it is not a huge job, just a matter of changing 8.1 into 8 in a number of dsf files, but if it is not something people have done before, it is easy to mess up.
    Regards,
    Richard
    You need to edit the dsf files, as well as move them, so that the base class is 8.0 rather than 8.1. Not rocket science, but it is something that should be done with care to ensure nothing is messed up.
    martin36 said:
    martin36 said:
    Havos said:
    martin36 said:
    Hey guy,
    I normally export to Daz format, but in reality for morph loading all that matters is that you re-import with the same settings as you exported with.
