Fitting Victoria 4 materials on G8M
I've run into a issue I'd like to solve, since I'd really like to use this material. For example, I have a V4 Material (makeup) for Poser which I have fit onto Victoria 4 in Daz Studio and saved as a material preset (.duf). I then used the Legacy UVs product to successfully fit this preset onto G8F. Properly fitting it onto G8M (which is my goal), however, is escaping me. I have the UV swap for G8 and the Cross-Figure kit products, if they can be in any way useful here. Is there any possible way to do this?
  • Richard HaseltineRichard Haseltine Posts: 111,688
    You would need legacy UVs for Genesis 8 Male, the female versions won't transfer across. Or you could try making Gensis 8 Female match the male character
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,652
    you could use map transfer on genesis 1 which has the UVs for V4 and M4 then use that with the legacy UVs for G8M
  • larinxlarinx Posts: 0
    Thanks a lot, I was not aware of map transfer as a function, this totally worked!
