How to install DSON?
in New Users
This is the error message I get:
"Install Manager cannot find a required path. The package for "DSON Importer for Poser (Win 64-bit)" requires that the installed path for "Poser Pro 2014, Pro 2012 (64-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again. "
The applications page of what? The settings dialog of what? Where?
Click the gear icon at top-right of the DIM interface to open preferences. Go to the Applicatiosn tab. Clock the + icon to add a new application. Select PoserPro as the name, set the version you are using (2012 or 2014) and set it to 64 bit, then click the ... button and select the folder with the PoserPro application in it. Click Accept to get back to the main interface and install the DSON Importer.
Thank you, seems to be working now.
