Sometimes the CPU renders even when is deactivated
Hi, selecting only "GPU" for the renders, for some unknow reason, sometimes the PC starts rendering with the CPU. Then i restart Daz Studio and... whoala, works with the GPU again without problems. I don't know why this happen, and i do the same things everytime.
Thx for the help.
  • AgitatedRiotAgitatedRiot Posts: 4,765
    Are you doing test renders?
  • GordigGordig Posts: 10,797
    Did you uncheck "Allow CPU Fallback" at the bottom of the advanced render settings? Checking only the GPU means that it will try to render only on the GPU, but if that fails, it will fall back to CPU if that's an option. Checking GPU and not CPU for devices means that it won't render on both CPU and GPU simultaneously, not that it won't render on the CPU at all.
  • Are you doing test renders?
    Yep, sometimes. Only happens like 1 of 10 renders.
    I just tried this. For now it works laugh
