Autofit/projection issues with G3F (solved)
Spydyr62
I am looking for a little help deducing what may have caused an issue I am having and how to correct it.
My G3F has recently stopped showing some of my options for my clones. It will allow me to pick the clone character (i.e. Genesis 2 of Victoria 4) just fine, but none of the options for what kind of clothing it is (i.e. shirt, short hair, full body, etc.) have been showing recently. I know it was working fine after I had installed Sickleyield's Ultra Templates for Genesis3 Females and Wear Them All - Autofitting Clones and Clothing Smoothers for Genesis 3 Female(s) from Valzheimer, because I had been using some of the new clothing options for dresses with bones from the products and such. I have included a snip that shows the autofit where it can select the clone but not the clothing style (clothing type is greyed and defaulted to none)
I have tried moving some of the G3F data folders and doing uninstall reinstalls of G3 essentials. Anyone have ideas what the problem or solution may be?
I can also add that my type of item choices on my other figures are working just fine it seems only G3F has been affected.
did you try reinstalling the Wear them all product? I see you said you reinstalled the essentials, but the wear them all is what gives you the templates for anything other than G2F.
Thanks for the post. I should have stated what I have tried already better.
Yes, I unistalled the Wear them all, SY Ultra Templates, and G3F Essentials and reinstalled.
I also tried doing the same after redownloading my installation packages (Deleted the packages through install manager and redownloaded and installed)
I have even gone as far as to move the entire Genesis 3 Folder in Data (Where the templates are showing up) and reinstalled just essentials...I did not even get the G2F templates loading up.
For G3F only, I get the intended figure selections but no item type selections available (They are grayed out as seen in the attached pics above). This is true no matter what intended figure I select when trying to autofit to G3F.
For autofit to figures other than G3F all is well. For example, when loading Genesis clothes on G2F, I get both the intended figure dropdown and the item type dropdown showing, enabled, and full of options.
I have a ticket in on it as well...hopefully between support, the wonderful people in the forums here, and some effort I will be able to figure it out without trying a full wipe on the Studio installs.
Got this solved. It seems I had a bad file in my library that was loading up G3F wrong somehow.
