Third Party Software Installed Via Install Manager?
Can 3rd party assets (made specifically for Daz Studio) be installed via Install Manager? I read that it could be somewhere, but I can't find where I read that now. If the answer is yes, are there instructions on how to do it?
Thank you.
  • crosswindcrosswind Posts: 10,312
    You may use Content Wizard to install 3rd party products and Content Wizard can export IM package which could be installed again by DIM. The benefit is that you may use DIM to uninstall the product afterwards.
  • marcelle19marcelle19 Posts: 181
    Thank you!
  • ShelLuserShelLuser Posts: 749
    Depends on the assets at hand. If you get a zip file then the only way to set this up is by unzipping it, or using another tool as hinted at above.
    If you want to avoid clutter in your main library then there's a very easy solution: just create an extra Daz library. Any folder on your system can be used as a Daz Studio library, supporting either the Daz or Poser formats. This is IMO the best way to keep a clear separation between your regular library (which you use to install assets as those bought on the Daz store) and 3rd party assets.
    If you want to look into this then press F2 while in Daz Studio, open the 'Content' tab and check the content directory manager option.
    Thank you, ShelLuser .
  • robertswwwrobertswww Posts: 806
    edited March 2023
    I too prefer to use Content Wizard for 3rd-party products and Export Zip Files from CW, then place the zip files in the Downloads folder specified in DIM settings. Launch DIM, choose "Work Offline" and your new files will show up in the "Ready to Install" tab.
    Optionally, you can create a 3rd-Party content folder on your hard drive (as @ShelLuser mentioned) and then add the folder location in Daz Studio prefs... Content Directory Manager (CDM).
    Here's a short video that shows the Step-by-Step for this process...
    How to Use Third Party Content in Daz Studio
    https://www.youtube.com/watch?v=wq_NkRRSc3E
    Post edited by robertswww on
    Thank you, everybody. I found that loading the zip files directly into the DIM downloads folder seems to do the trick nicely.
  • I had stopped using Daz Studio for a while, and when was able to get back to using it, found that the zipped 3rd party files that fomerly would install via DIM no longer do so under the new version of Daz which came out while I was not using it.
    Oh, well.
    Oh, well.
    What happens when you try?
    Richard Haseltine said:
    Oh, well.
    Sorry, Richard. I hadn't seen this reply.
    I just posted to another thread where someone asked how to change the directories and folders DIM installs to just a few minutes ago.
    When I've tried to install unzipped files into the downloads folder for DIM, it just doesn't "see" them any longer, apparently. While this was a great way to install unzipped 3rd party Daz products before, it just doesn't work, now.
  • Richard HaseltineRichard Haseltine Posts: 111,619
    So they are not appearing in DIM or in Daz Studio? I am not clear from your post since you say they used to work in DIM, that now theya re not appearing, and that you manually unzip them. Do remember that zips will usually contain an extra folder (Content, My Library, My Daz 3D Library or even the product name) that you do not want in the content folder.
    edited July 2025
    Thank you, Richard. Yes, I know about the extra folders, and don't install those in the library.
    Most of the time, unzipping to the Daz Library works - every once in a while, something gets a little weird.
    I use 7Zip, and to change the folders to regular zip is something I have tried to do, according to instructions I've read, so that they could be used by DIM, but until I get that right, the best I can do is unzip them and place the people, data, runtime, props etc. folders in the Daz Library folder, which, like I said, works most of the time.
    Post edited by marcelle19 on
    DIM requires a specific structure to the zip and the .dsx data files that describe the contents and where they should go - it isn't just a file format issue.
    That's too advanced for me - I don't even understand it.
  • Steve KSteve K Posts: 3,535
     Here is what I decided was the easiest.  This is from the README file of a non-DAZ product for DAZ Studio:
    QUOTE
    **************************  INSTALATION   *******************************
    Unpack Poser zip files to Your Poser Runtime folder.
    The model will be placed in
    runtime/library/Character/Coflek Gnorg/Pulp Sci-Fi
    Unpack Daz Studio zip files to your DAZ 3D Library
    Vehicles\Coflek Gnorg\Pulp Sci-Fi
    END QUOTE
    Attached is a screenshot of what happens, it ends up in "My Library" (which I selected for the Unzip), not "My DAZ Connect Library", which is fine.  You just have to "Load" the DSON User file from the "Pulp Scifi" folder, i.e. it does not show up in the DAZ Studio Content Tabs.
    245 x 552 - 48K
  • LeanaLeana Posts: 13,543
    Installing content manually to "My Daz Connect library" wouldn't work, it's only for content installed with Connect and DS will ignore anything else.
    If you add "My library" as a content library in DS preferences it will show up in "content library" tab, and you can then categorize it if you want it to appear in Smart Content.
    Yes, my screenshot shows "My Library" but not "DAZ Connect Library".
    Good to know, thanks.
