Stupid me??
I purchased Jepe's Wonder Sheetz on the strength of there being a Dson installer included as I hoped to be able to use in in Poser. However I cannot figure out how to import it into Poser as now files were included for Poser. I didn't have high hopes of doing the kind of thing I might do in Studio but for my usage I though it would work. Doesn't appear so Am I missing some thing? Am I stuck with something I can't use?
  • thd777thd777 Posts: 946
    A DSON installer is NOT for Poser. It is the standard DAZ Studio format. For Poser you need to look for "Poser Companion Files".
    If those are not inlcuded you can make your own using DAZ Studio. Not very hard to do. There is also a Poser script from Dimension3D that allows you to import DSON format directly if I recall correctly.
    TD
  • cclesuecclesue Posts: 420
    edited September 2015
    For some one NOT familiar with DAZ Studio making my own Pser companion files might be a monumental task so where would i find the Poser script from dimension3d
    OOps just found this is this it?
    200 x 200 - 12K
    Post edited by cclesue on
    You can get the script here: http://d3d.sesseler.de/index.php?software=poserpython&product=dson_loader
    I have used it in the past, but not recently. I rarely bother with Poser these days, just for the occasional foray into the clothroom and then back to DS. The script should allow you load the content. How this particluar set will work in Poser, I can't say. If you are using default shapes it might be ok. For morphed figures, I have to use smoothing and collision detection in DS and that is not available in Poser.
    Good Luck
    TD
    EDIT: Yes, that is it.
    Post edited by thd777 on
  • LindseyLindsey Posts: 2,017
    The Sheetz products I bought for the Genesis 2 Figures includes a Poser Companion File (PoserCF) installer.  If you don't use DIM (and have the filters setup properly), you can download it from your product library.  If you purchased the V4/M4 products, the readme online implies there should be a Poser Core files installer with obj, mc6, mt5 and pz2 files.
