Iray and where I load various maps
So I see this a lot when doing research on DAZ: Add a specular map, add a bump map, add a transparency map, add a transluency map.
My questions is simple. Into what options do I load these different maps after having converted a materal to the Iray shader?
  • frank0314frank0314 Posts: 15,098
    on the surface tab you will see all the different places to apply the maps to.
  • Not really, there is no option after I apply the Iray shader that says specifically: Specular map :(
  • IceCrMnIceCrMn Posts: 2,333
    edited September 2015
    Here's where I put them
    "Base Color" = colored texture
    "Glossy Layered Weight" = specular
    "base Bump" = bump
    "Normal Map" = Normal
    "Top Coat Base Bump" depending on your mode either bump/height  or normal
    "Cutout Opacity" = transparency
    "Displacement Strength" = displacement
    Hope this helps out :)
    edit: ooops forgot the base color
    Post edited by IceCrMn on
  • Yes, that's going to take a little getting used to — all the names of the surfaces parameters are different, and it isn't always obvious what corresponds to the old names.
    Thanks from me too icecrmn. Made a note of this for later reference.
